Fujitsu Lifebook E546 RAM Modules Replacement
  1. Fujitsu Lifebook E546 RAM Modules Replacement, Removing battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before doing something, always remove the battery!
    • First, gently pull down and hold that little tab down (1) to unlock the second tab.
    • Then move left the second tab (2). Both tabs should be secured in OPEN position.
    • Now you can pull battery out by simply lifting it by that notch (3).
  2. Fujitsu Lifebook E546 RAM Modules Replacement, Removing RAM modules cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove RAM modules cover, just undo one screw (highlited in photo). Then lift cover by notch next to the screw hole.
  3. Fujitsu Lifebook E546 RAM Modules Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you can see you RAM modules bay. RAM stick is held by two clips - one at each side.
    • Gently pull the tabs outwards. Released RAM stick should pop-up upwards to certain angle.
    • Gently remove RAM stick. To insert a new stick, push it into slot at an angle. Make sure it is evenly seated, then push it down until clips will secure it.
Michał Kurda
crwdns2935283:002/17/22crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 338
