Fujitsu Lifebook E546 Keyboard Replacement
  1. Fujitsu Lifebook E546 Keyboard Replacement, Removing battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before replacing anything from your laptop, remember to remove the battery.
    • Pull down and hold the little tab (1). Then move the second tab (2) left. Now your battery lock should be secured in OPEN position.
    • Pull battery out by that notch (3) in the middle.
  2. Fujitsu Lifebook E546 Keyboard Replacement, Removing plastic cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook E546 Keyboard Replacement, Removing plastic cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu Lifebook E546 Keyboard Replacement, Removing plastic cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now remove eigth (8) screws. At the picture, lower two are from keyboard, upper 6 are for plastic cover (second picture) between screen and keyboard.
    • With screws removed, you can remove that plastic piece (second picture) by gently pulling it out from either of sides (picture 3). Using some plastic tool or guitar pick is recommended.
  3. Fujitsu Lifebook E546 Keyboard Replacement, Removing keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu Lifebook E546 Keyboard Replacement, Removing keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, with plastic cover removed, simply pull keyboard upwards. Not too hard, since it is still connected to the motherboard.
    • There is ZIF (Zero Insertion Force) socket. Use some wooden pick or thin plastic tool to open the connector by pulling out that brown part by either of sides.
    • With connector open, keyboard cable should be free to pull out. Do not use force, as these are delicate parts.
    • Connecting cable back is a bit tricky - make sure cable is seated properly and tab pushed in and secured.
Michał Kurda
crwdns2935283:002/17/22crwdne2935283:0
920 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 1,189
