Fujitsu Lifebook E546 HDD/SSD Replacement
  1. Fujitsu Lifebook E546 HDD/SSD Replacement, Removing battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First of all, remove your battery.
    • Pull and hold the little tab (1) down.
    • The move second tab left (2). Both tabs should be now secured in open position.
    • Now you can lift up battery by that notch (3). That's it.
  2. Fujitsu Lifebook E546 HDD/SSD Replacement, Removing HDD/SSD cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • To remove HDD/SSD bay cover, undo one screw.
    • Then pull the cover up by that notch. Use some force since cover seats quite hard. This should be done by finger, but if can't do it that way, use some plastic card or guitar pick.
  3. Fujitsu Lifebook E546 HDD/SSD Replacement, Replacing HDD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now with HDD cover off, we can remove our disk.
    • Gently press on the disk and move it lelt - away from SATA connector, until it'll be disconnected.
    • Then, pull it upwards and out of HDD/SSD bay. Don't forget about that rubber element as it is a part form laptop, pull it off of old HDD and push it onto new one.
    • Beware! This laptop can only fit slim (7mm thick) 2,5" HDDs! Normal sized old HDDs may not fit. 2,5" SSDs regular thickness is 7mm, so they should fit.
    • To insert new disk, aim to insert the connectors first, then gently press it down into the bay.
Michał Kurda
crwdns2935283:002/17/22crwdne2935283:0
920 crwdns2915208:0crwdne2915208:0
Hi Sir . I have a probleme about my laptop.
So how can format my laptop please🤌🤌
Mouaad Mouaad - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 2,373
