Fujitsu LifeBook N3510 Wireless Module Replacement
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two clips on the bottom of the computer that support the battery.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to partially lift the hinge cover.
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to release the ribbon cable from the motherboard.
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After the ribbon has been detached, carefully remove the keyboard.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Metal Motherboard Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the cover with fingers and remove.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Display: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove labeled screws.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screws from the bottom of the hinge as shown in the image.
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to detach and remove cables from the motherboard.
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug highlighted cables from the wireless module.
    5. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Top Palm Rest Cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 labeled screws.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove screws from bottom of laptop as shown in the picture.
    3. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the palm rest cover from the base of the laptop.
      • You may use spudger if needed, lift from the front corners as shown.
    4. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Great job! You have successfully removed the old palm rest cover.
    1. Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push securing clips outward, the wireless module will pop out.
      • Remove the wireless module.
    2. Fujitsu LifeBook N3510 Wireless Module Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • A picture of the removed wireless module is shown to the left.
Neil Daniels
crwdns2935283:001/17/11crwdne2935283:0
1,411 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 5-18, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-18, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G18
crwdns2935297:0132crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 3,043
