Fujitsu LifeBook N3510 Optical Drive Replacement
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two clips on the bottom of the computer that support the battery.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
    3. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to partially lift the hinge cover.
    4. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
    5. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to release the ribbon cable from the motherboard.
    3. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After the ribbon has been detached, carefully remove the keyboard.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Metal Motherboard Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the cover with fingers and remove.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Display: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove labeled screws.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screws from the bottom of the hinge as shown in the image.
    3. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to detach and remove cables from the motherboard.
    4. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug highlighted cables from the wireless module.
    5. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Top Palm Rest Cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 labeled screws.
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove screws from bottom of laptop as shown in the picture.
    3. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the palm rest cover from the base of the laptop.
      • You may use spudger if needed, lift from the front corners as shown.
    4. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Great job! You have successfully removed the old palm rest cover.
    1. Fujitsu LifeBook N3510 Optical Drive Replacement, Optical Drive: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single screw labeled "5".
    2. Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Optical Drive Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove optical drive.
Neil Daniels
crwdns2935283:001/17/11crwdne2935283:0
1,411 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 5-18, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-18, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G18
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 2,209
