Fujitsu LifeBook N3510 Fan Replacement
crwdns2869540:0crwdne2869540:0: 4.7K
5
22
97
4,698
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
    1. Fujitsu LifeBook N3510 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the two clips on the bottom of the computer that support the battery.
    2. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
    1. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    2. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
    3. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to partially lift the hinge cover.
    4. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
    5. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    1. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
    2. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to release the ribbon cable from the motherboard.
    3. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After the ribbon has been detached, carefully remove the keyboard.
    1. Fujitsu LifeBook N3510 Fan Replacement, Metal Motherboard Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
    2. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the cover with fingers and remove.
    1. Fujitsu LifeBook N3510 Fan Replacement, Fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Fan: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement, Fan: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Detach fan cable from motherboard.
    2. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove labeled screws.
    3. Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LifeBook N3510 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove fan.
Neil Daniels
crwdns2935283:001/17/11crwdne2935283:0
1,411 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 5-18, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-18, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G18
crwdns2935297:0132crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 97
crwdns2959996:0crwdne2959996:0 4,698
