Fujifilm X20 Fuse on main PCB replacement
TomA
crwdns2944107:0crwdnd2944107:0TomAcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 8, 2024crwdne2944111:0
2 - 3 crwdns2931253:0crwdne2931253:0
crwdns2937803:0crwdne2937803:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
My Fuji X20 camera failed to switch on. In fact it did not react to any button or to the switch on the lens ring. I used the disassembly guide here to take it apart and then traced the fault to a blown input fuse on the main printed circuit, near to where the battery wires connect. I’ve identified this fuse as a SMD 2.5A rated fuse, 0603 size.
  1. Fujifilm X20 Fuse on main PCB replacement, Screws on the bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and the SD-Card.
    • Remove the three marked screws from the bottom of the camera.
  2. Fujifilm X20 Fuse on main PCB replacement, Finding the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Finding the screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four pieces of leatherette from the front and the back of the camera. Lift the edge of the leatherette and pull. The material itself is quite sturdy and the glue will still be good if you re-apply the pieces after you are finished.
  3. Fujifilm X20 Fuse on main PCB replacement, Screws on the back 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Screws on the back 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Screws on the back 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws from the left side of the camera
    • Remove three screws from the right side of the camera
    • Remove the screw between the Q and the DISP/BACK button.
  4. Fujifilm X20 Fuse on main PCB replacement, Screws on the back 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw hiding below the rubber-pad.
  5. Fujifilm X20 Fuse on main PCB replacement, Screws on the front: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Screws on the front: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Screws on the front: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws from the left side of the camera.
    • Remove two screws from the right side of the camera
    • Remove nine screws from the front of the camera.
  6. Fujifilm X20 Fuse on main PCB replacement, Remove the bottom cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove the plastic base cover.
    • Below you will see two more screws. Please remove them as well.
  7. Fujifilm X20 Fuse on main PCB replacement, Remove the back cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Remove the back cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now the two metal covers will get loose. Start by removing the back-cover containing the LCD.
    • Open the connector holding the FPC (the orange wiggly thing) and remove it.
    • You open the connector by lifting the little clip on the opposite side of the oranged FPC (second picture). Then you can pull out the orange FPC.
  8. Fujifilm X20 Fuse on main PCB replacement, Insides 1: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Insides 1: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Insides 1: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws (red).
    • Disconnect the FPC on the left side (green rectancle). You have to open the lever.
    • Remove the copper foil from the upper part, but do not remove it completely (pink rectangle).
    • The small round part on the bottom is the beeper. Free the connecting wire from the white duct tape. The beeper itself is glued in his place and can easily be removed by pulling.
    • On the left side is one FPC left. This connector can not be opened, the FPC must be removed by pulling (blue-ish rectangle)
  9. Fujifilm X20 Fuse on main PCB replacement, Inner parts: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Inner parts: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally! You can move the steel part away and by opening the last remaining FPC connector on the main PCB you can remove this steel thing completely.
  10. Fujifilm X20 Fuse on main PCB replacement, Cameras ready, prepare the flash.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Cameras ready, prepare the flash.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Cameras ready, prepare the flash.: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cameras ready, prepare the flash. You will now access the flash capacitor. This can be dangerous. If you are not sure, do not continue.
    • The capacitor for the flash can hold dangerously high voltages. I measured 260V across the terminals 2hrs after disconnecting the battery. Either monitor the voltag with you multimeter until it is safe or discharge the capacitor using an resistor of adequate wattage. Do not short circuit the terminals of the capacitor.
    • Remove the screw below the white plastic.
    • Remove the lower FPC as well. This connector does not have a lever. Remove the cable by pulling.
    • You can now remove the little PCB from the housing.
  11. Fujifilm X20 Fuse on main PCB replacement, Remove the top cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Remove the top cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Remove the top cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ok, only two steps, then the top-cover can be removed.
    • First, remove the marked FPC from its connector. This leads to any button or wheel on the silver top part.
    • The remove the tiny screw beneath the viewfinder on the front with an TORX T1.
    • Then you can remove the silver top cover by pulling.
    • The big capacitor will still be attached.
  12. Fujifilm X20 Fuse on main PCB replacement, Disconnecting the main PCB: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Disconnecting the main PCB: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the right PCB by disconnecting the remaining three FPCs.
    • This part (PCB and containing plastic) can now be removed as well.
  13. Fujifilm X20 Fuse on main PCB replacement, Separate the lens from the body: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Separate the lens from the body: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Separate the lens from the body: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lens is screwed with four big screws to the body.
    • Two screws on the bottom are easily accessible
    • One screw on the top left is also easy to reach.
    • The fourth screw is a bit hidden under two FPCs. You don't have to remove these FPCs to remove this screw.
  14. Fujifilm X20 Fuse on main PCB replacement, Removing the sand.: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do you still remember why I opened the camera in the first place? Because I could not turn the lens any more due to sand.
    • I found some sand lodged between the big and the little gear shown on the picture. I turned the lens so that the opening pointed down and carefully turned the lens back and forth. A very small amount of sand fell out but it was enough to get things going again.
  15. Fujifilm X20 Fuse on main PCB replacement, HELP: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, HELP: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two pictures showing a) the parts and b) the screws and their position.
    Thanks a lot for this great instructions. Today I am a bit shy to follow your guide immidiatly. However I let the things work in my brain and maybe in a few days I start disassembly. I have also some sand within the lens which make the repair more difficult. But this is a start Point I waited for 3 years. Thank you.
    Jochen - crwdns2934203:0crwdne2934203:0
  16. Fujifilm X20 Fuse on main PCB replacement, Disassemble the camera following the guide here on Ifixit: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If a X20 camera fails to react to the "on switch" and the play button on the back it could be due to a faulty fuse on the main PCB.
    • If you suspect this is the case (likely if nothing else works, even with new / freshly charged batteries) and if you are confident to work on SMD boards follow the disassembly guide for the X20.
    • This will eventually give you access to the main PCB which is fitted to the battery compartment.
    • Remove the whole battery compartment from the camera, and unscrew the PCB from the chassis. It will then look a bit like this.
  17. Fujifilm X20 Fuse on main PCB replacement, Locate the fuse on the PCB.: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 Fuse on main PCB replacement, Locate the fuse on the PCB.: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fuse is located close to where the red battery wire is soldered to the PCB.
    • As far as I can make out it is a 2.5A rated fuse (marked with an O). Sadly it is not possible to detect the speed rating of the fuse.
    • With an Ohms meter probe the fuse i.e. check if there is continuity from one side to the other. If the fuse is OK there will be almost 0 Ohms across it. If the fuse is blown it will show open circuit i.e. infinite resistance.
  18. Fujifilm X20 Fuse on main PCB replacement, Replace the fuse.: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replacement fuses are available form electronic component suppliers. If you can get hold of one and have a suitable soldering iron you can replace it. It is a 0603 size, about 1.6 x 0.8 mm in size.
    • Ideally this is done with a "tweezer" style iron which heats both ends of the fuse at the same time.
    • Remove the old fuse (it may need a bit of force, mine was glued to the board) and fit the new one in the same place, making sure both ends are well soldered to the board.
    hi TomA,
    I really appreciate that you made this guide cause I’m having similar issues with mi X20 and I don’t have enough money to buy a new machine. It seems that this same Fuse is not working on my camera. So now I’m searching on internet for a new fuse to replace it and I am just discovering that there is a letter code for this kind of materials. So probably this Fuse is marked with the code O. But I did’nt found fuses with the code O, only with H, D and P... Do you know if there is a significant difference between this codes? Do you know Which one can I pick to complete this repair?
    If you eventually got more pictures or if you can relate more aspects that you have not shared yet on this guide, it could be really useful if you manage to do it. Actually, this is the first time on my life that I go so far on repairing something and I don’t even know if really did what i should using the multimeter, etc.
    Regards, guilevar
    guilevar - crwdns2934203:0crwdne2934203:0
    Hi Guilevar,
    The O on the fuse most probably refers to the current rating, I believe this is 2.5A. Different manufacturers will use different codes for the same rating. In fact the spare part I fitted has a T on it but it is a 2.5A fuse. The only uncertainty is about the speed rating for the fuse (quick-blow, slow-blow/delay). I have no way of identifying this from the original part, but I decided to fit a “slow-blow” type - I didn’t want having to go through this again…
    So far the camera is working fine, it would be a shame having to replace it.
    Best regards,
    Tom
    TomA - crwdns2934203:0crwdne2934203:0
    • When done screw the PCB back onto the battery compartment and reassemble the camera by reversing the steps of the assembly guide.
    • If there was no other fault present the camera should work fine - mine certainly did!
    hi i have X-20 have focus problem ,not focusing , i dont know where its problem Lense or in camera , thankyou
    Uta - crwdns2934203:0crwdne2934203:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
TomA
crwdns2935283:005/14/20crwdne2935283:0
149 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Hi!
Did you measure what’s the resistance to ground is for this fuse? I try to repair my camera (actually it’s Sony, but the principle is important) an I get 0.4 ohms to ground. I’m just affraid there are short circuits all around and don’t know whether that’s near normal or not.
Anri - crwdns2934203:0crwdne2934203:0
Hi, I did not measure the resistance to ground, but I would expect it to be very high, kOhms or more. The fuse sits in the positive supply and that should show a very high impedance to ground. Your measurements do indeed point at shorts or other faults.
Messive work, how long it takes?! I think I wouldn't dare...
amdesidik - crwdns2934203:0crwdne2934203:0
Thank you for this complete tutorial. I just bought one used with the same issue. I might go to the electronic store tomorrow hoping they got the part. I don't have a microscope but I have a thin soldering tip as well as lot of space here compared to a laptop (yea...). I hope it will be a success !
unnute - crwdns2934203:0crwdne2934203:0
Same issue here, didnt turn on after bought second hand. With a soldering iron, a tweezer and some patience i swapped the tiny fuse with a new one and everything works nicely now ! Thanks a lot !
VVavanee - crwdns2934203:0crwdne2934203:0
Hi, any idea what the problem could be beside the fuse? Measured it and seems to be ok. Camera won´t turn on. I disassembled the whole camera and I couldn't find any burn marks or obviously damaged parts. BTW very helpful disassembly guide, thank you :)
Simon - crwdns2934203:0crwdne2934203:0
It works? Having thought all was lost with my X20 when it refused to turn on I sent it to Fujifilm for quote to repair and quoted AUS950. Ouch. No thanks. So, asked my techi friend and his techi son who can fix everything followed the guide and replaced the fuse (piggy backed onto the old one), put it back together and it works perfectly!!! Thank you so much for the instructions. JonS
Jonathan Stagg - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 2,140
