Fujifilm X20 - On-/Off-Switch Repair
  1. Fujifilm X20 - On-/Off-Switch Repair, Screws at front: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Screws at front: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you start remove batterie and SD-card!
    • Take notes of all screw's positions! The best way to do that is to use a magnetic project mat.
    • I removed the rubber covering completely to find all screws, but if you know the positions you can leave most rubber on and just remove it at the edges to access the screws. The rubber will stick well again after the repair but is very difficult to reattach after complete removal.
    • Remove all screws marked red, the screws with green marks can stay in for now.
    • Almost all screws are cross headed, except for one T2 size torx screw.
  2. Fujifilm X20 - On-/Off-Switch Repair, Screws at sides and back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Screws at sides and back: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Screws at sides and back: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all screws marked red.
  3. Fujifilm X20 - On-/Off-Switch Repair, Remove bottom plate and open back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove bottom plate and open back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove bottom plate and open back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you open the camera make sure you are electrically ground to earth. The best way to ensure that is to work with ESD-rated equipment such as wristband, mat and special srew-driver. Electrical discharge into the cameras electronics will lead to severe damage!
    • After opening the bottom plate you will see the speaker on the position marked with a blue circle. In my case the cable detached trying to remove it, but since I never used the speaker I didn't care. You will need to find another way around it if you want to keep the speaker, shouldn't be to difficult now that you know how the next steps look like.
  4. Fujifilm X20 - On-/Off-Switch Repair, Remove back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach cable marked red opening a little bar on the switch to detach the backplate with screen.
    • Remove cables and screws on left side to remove the little PCB, that will enable to remove the metal cover.
    • In third image the blue circle marks the solder points the little speaker is attached to, shouldn't need to desolder I think.
  5. Fujifilm X20 - On-/Off-Switch Repair, Remove internal back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove internal back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove internal back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The little PCB can be taken of the cable, also screws to be removed to detach the metal cover. The metal cover is attached to another cable on it's back.
  6. Fujifilm X20 - On-/Off-Switch Repair, Remove top plate with flash unit: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove top plate with flash unit: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove top plate with flash unit: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To cables to be removed to detach the top bit of the camera, the flash unit including the capacitor can remain attached to the top section.
    • WARNING: Be carefull with the flash unit capacitor, risk of very high voltage!
  7. Fujifilm X20 - On-/Off-Switch Repair, Remove lens/sensor unit: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove lens/sensor unit: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Remove lens/sensor unit: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 4 screws hold the lens/sensor unit in place.
  8. Fujifilm X20 - On-/Off-Switch Repair, For the full teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, For the full teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, For the full teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For the full teardown remove the two screws marked in red to take of the battery compartment.
  9. Fujifilm X20 - On-/Off-Switch Repair, What's broken?: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, What's broken?: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Showing the mechanism that moves during zooming the lens and switching the camera on as well. Zooming the lens moves the black slider along the metal rail and activates the on-switch sitting inside. That works via a small white gearwheel that is connected to the black slider. The wheel also tells the camera electronics the current zoom position.
  10. Fujifilm X20 - On-/Off-Switch Repair, Fix on-/off-switch mechanism: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Fix on-/off-switch mechanism: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Fix on-/off-switch mechanism: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In my case the black slider could tilt towards the rails, disconnecting the white gearwheel and therefore all electronic functions of the zoom mechanism.
    • To fix that I glued the bit of plastic onto the backside of the black slider, preventing it from tilting towards the rail. Before fixing the slider position make sure it’s in the right position to show the exact focal range later in camera.
  11. Fujifilm X20 - On-/Off-Switch Repair, Broken lens fitting point: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X20 - On-/Off-Switch Repair, Broken lens fitting point: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I found that the lens must have been knocked at some point since one of the lens fixing points were broken off (I assuming that must have broken the switch as well, maybe at the position marked blue in step 9 image 2).
    • To fix this I reattached the fixing point using superglue.
  12. Fujifilm X20 - On-/Off-Switch Repair, Success!: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-assembled the camera working my way backwards through the steps, it is working fine now. Good luck!
    To help other x10 x20 owners, I fixed my on off switch by removing the bottom part off my x10.
    At the bottom of the lens you will see a copper piece moving when you turn the lens on and off.
    You can spray a contact cleaner on this copper part and turn on and off several times to clean the contact.
    I hope you will be as succesfull as me and enjoy your camera again
    Bertrand CASNABET - crwdns2934203:0crwdne2934203:0
Manuel Fohler
crwdns2935283:004/19/15crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
Hello, i’ve try to repair my X20 who seemed to have the same probleme of on/off switch: the camera start in play mode but when i turn the on/off switch everything go’s to black and i can’t anymore go to the play mode. A disassembly the camera with your guide but i didn’t understand how exactly your repair it. What about the small plexiglass part you insert and why did it fix the pb ? Should i do exactly the same action to make my camera ready for some more pictures ?
Tank you for the disassembly guide which work perfectly.
jordi Duchemin - crwdns2934203:0crwdne2934203:0
I’m glad the pictures helped you so far. The plan was to add more text at some point, especially the part with the actual fix isn’t very clear. So let me explain a bit more detailed how I fixed the on/off switch in my X20:
In the first picture of step 10 you see the metal rail and the black slider sitting on top. If you turn the lens the slider should move along the rail and activate the on switch sitting inside. That works via a small white gearwheel that is connected to the black slider. In my case (and I hope you find the same situation in your camera) the black slider could tilt towards the rails, disconnecting the white gearwheel and therefore all electronic functions of the zoom mechanism.
To fix that I glued the bit of plastic onto the backside of the black slider, preventing it from tilting towards the rail. Before you fix the slider position you need to make sure it’s in the right position to show the exact focal range later in camera.
If you should have more questions you are welcome to write me again.
Manuel Fohler -
I’m looking forward to when you add more description to these photos. I have the same issue with my X20 since last week. I turn the lens, there is sign of power, then its off. I know that the battery is good and fully charged. I can turn on the playback function no problem. I am reluctant to rip into the camera before I understand better what I need to do.
rrcp - crwdns2934203:0crwdne2934203:0
Hello,
It is difficult to say what the usual reason for this on/off-switch issue is. I think my case was special because I found that the lens must have been knocked at some point, in step 11 you can see that one of the lens fixing points were broken off and that must have broken the switch as well.
The on/off-switch problem appears more often but I think it can have different sources. The only way to find out, without sending it to service, would be do open it and have a look. I found a video of someone opening his X10 (which is a very similar design) and explaining how he fixed his camera having also trouble with the switch but with a different cause, maybe that helps: https://www.youtube.com/watch?v=dKn16FJT...
If you have any questions in particular please let me know.
Best wishes,
Manuel
Manuel Fohler -
Added some descriptions now as well, hope that helps.
Manuel Fohler - crwdns2934203:0crwdne2934203:0
Hallo Herr Fohler, meine X20 löst irgendwie eigenartig aus und hat ein eigenwilliges knacken beim inzwischen echt schweren zoomen. Was würde es denn kosten, wenn Sie mir die Kamera reparieren würden, wenn ich ein neues Objektiv bestelle? herzliche Grüße aus dem Taubertal Hannes Hofmann @ gmx.de / wein-notizen.de
Hannes Hofmann - crwdns2934203:0crwdne2934203:0
Hallo Herr Hofman,
Freut mich, dass Sie mir die Reparatur Ihrer Kamera zutrauen. Ich repariere allerdings nicht professionell und kann keinerlei Garantie auf Erfolg geben, und bei der Raparatur kann einiges schief gehen. Ich habe selbst bei Ebay Ersatzteile für das Objektiv aus China gesehen, wahrscheinlich stammen diese aus alten Kameras, meinen Sie ein solches Ersatzteil? Diese Teile werden ohne Sensor und soweit ich sehen kann auch ohne Elektronik für den Sucher angeboten, es müsste also mehr auseinander gebaut werden als ich es hier getan habe. Grade bei dem Sensor ist dann staubfreies Arbeiten wichtig und auch die genaue Justage beim Zusammenbau. Ich wäre eher abgeneigt diese Reparatur zu versuchen, zumal es auch zunächst eine Investition gibt (Ersatzteil plus Versandkosten zwischen Deutschland und England wo ich derzeit wohne).
Haben Sie mal den Fujifilm Service kontaktiert? Dort sollte die Kamera eigentlich noch repariert werden können, eine Anfrage kann sicher nicht schaden denke ich.
Viele Grüße,
Manuel
Manuel Fohler -
Good morning. I have to replace the display of the x20. just that. do you have a tutorial? thanks
Franco La Valva - crwdns2934203:0crwdne2934203:0
Hi,
Changing the display is quite easy. You can follow steps 1-3 to remove the bottom cover and then partly step 4 for the back cover, the screws for the front part of the camera can stay in obviously. The speaker I mention shouldn’t be a problem for you since you only need to get the back cover off.
On the back cover shown in picture 2 of step 4 you need to take the circuit board off which is held by 3 screws as far as I can see, that is needed to access the flat cable from the display to the board. The display itself should only be held with glue. If you need more help from there please upload a picture somewhere so I see how it looks like.
Hope that helps, let me know if you have any specific questions.
Good luck,
Manuel
Manuel Fohler -
My X20 doesn’t turn off when I turn the lens to off position. Camera stays ON. I have to remove the battery to turn it off. Any suggestions how to fix it? Thank you
Eugen Agat - crwdns2934203:0crwdne2934203:0
hi i have X-20 have focus problem ,not focusing , i dont know where its problem Lense or in camera , thankyou
Uta - crwdns2934203:0crwdne2934203:0
Hi, could it be a problem with the focus button half pressing? You can try setting the camera to continuous AF to see if it changes focus, that way you get a better idea of the cause. Best wishes, Manuel
Manuel Fohler -
hi manuel,
mine was about the lense as well, it turns on and off no problem but when i’m zooming in and out, the camera takes photo by itself, any idea which part is broken? thanks for the post!! very detailed steps and pictures
sarah - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 9,298
