Fujifilm X100V Main board Replacement
  1. Fujifilm X100V Main board Replacement, Peel off leatherette: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Peel off leatherette: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off leatherette on the back left side, near the LCD and the viewfinder. It reveals two screws.
  2. Fujifilm X100V Main board Replacement, Unscrew the bottom panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Unscrew the bottom panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew five screws. No need to touch the pair near the mounting hole.
  3. Fujifilm X100V Main board Replacement, Unscrew port panel cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two screws.
    • Carefully pry off the port cover panel together with the flap cover. Try not to damage the spring.
  4. Fujifilm X100V Main board Replacement, Unscrew two screws under the letherette: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew these
  5. Fujifilm X100V Main board Replacement, Unscrew two screws under the LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the LCD panel
    • Unscrew two screws near the top
    • Note that they are of different length, the one near the viewfinder is longer.
  6. Fujifilm X100V Main board Replacement, Take off the back cover with the LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Take off the back cover with the LCD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the cover out. It may be held by the two blocks of thermal paste (yellow markers).
    • Pull off the white ribbon cable. Before pulling out the orange one, unlock the bar on the connector. See red markers.
    • Use a thin tip spludger to unstick rubber foam near the viewfinder that may be holding the back cover.
  7. Fujifilm X100V Main board Replacement, Disconnect cables on the visible side: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Disconnect cables on the visible side: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off black (and one white) sticky patches that cover connectors.
    • Remember which patch goes to which spot.
    • Pull off the white ribbon cable (yellow marker)
    • Unlock and disconnect orange cables.
    • Unsolder the speaker.
  8. Fujifilm X100V Main board Replacement, Unscrew the motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew four screws
    • Slightly bend the board to release it from the plastic hook (yellow marker)
  9. Fujifilm X100V Main board Replacement, Disconnect cables from the hidden side of the board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Disconnect cables from the hidden side of the board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect two ribbon cables.
    • Unsolder four wires going to the battery.
  10. Fujifilm X100V Main board Replacement, Transfer sticky pads to the new board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the round foam pad and all patches and reattach them to the replacement motherboard.
    • Be careful with the patch with copper foil (not on the picture), it is fragile.
  11. Fujifilm X100V Main board Replacement, Solder battery wires: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I am rather ashamed, but hey, it works!
    • My Hakko FX888D could not sufficiently heat the pads, I had to use a bigger soldering iron.
  12. Fujifilm X100V Main board Replacement, Connect downside cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Connect downside cables: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect and lock the wider cable
    • Insert the narrow cable. It is rather fiddly, you need to push it from the side with a pinzette.
  13. Fujifilm X100V Main board Replacement, Connect upper side cables: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the board in place and under the hook.
    • Connect and lock all the numerous upper side ribbon cables.
    • Solder the speaker
  14. Fujifilm X100V Main board Replacement, Screw the board in place: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X100V Main board Replacement, Screw the board in place: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the board with four screws.
    • Put in place sticky patches.
  15. Fujifilm X100V Main board Replacement, Connect the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect two ribbon cables.
    • Put in place two blocks of thermal paste
    • Put the back cover in place.
    • Carefully bend out the spring of the port panel cover and put the cover in place.
    • Screw six screws that hold the back cover.
    • Close and screw the bottom cover
crosser
crwdns2935283:003/04/24crwdne2935283:0
288 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 187
crwdns2942667:0crwdne2942667:0 2,384
