Fujifilm X-M1 LCD Screen Replacement
    1. Fujifilm X-M1 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the camera upside down to locate the battery compartment.
      • Slide the button up to open the compartment.
      • Slide the orange button up to release the battery.
      • The battery is not shown in these photos.
    1. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Twist the lens cap to remove it from the camera.
      • Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
      • Use tweezers to remove the top metal ring and the thin metal ring below it .
    2. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4.3 mm Phillips screws inside the lens assembly.
    1. Fujifilm X-M1 LCD Screen Replacement, Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
    2. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
      • Remove the 3.4 mm Phillips screw.
      • Remove the 3.7 mm screw.
    3. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
      • Remove the 3.2 mm Phillips screw.
      • Remove the 3.8 mm Phillips screw.
      • Remove the 2.8 mm Phillips screw.
    4. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers to slide the metal shield straight out of the external flash mount.
    5. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 4.6 mm Phillips screws from the external flash mount.
      • Use tweezers or two fingers to remove the mount clip.
    6. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Extend the LCD.
      • Remove the two black 4.3 mm Phillips screws from the back case.
    7. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
    8. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slowly pull the back frame away from the camera.
      • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
      • Use tweezers to pull the white and blue ribbon cable out of the connector.
    9. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the frame around the LCD to remove it from the camera.
    10. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
    11. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers to unhook the speaker near the left handgrip.
    12. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly lift the metal frame away from the motherboard.
      • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
      • Use tweezers to remove the plastic covering the motherboard.
    13. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
      • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
      • Remove the back case.
    1. Fujifilm X-M1 LCD Screen Replacement, LCD Screen: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement, LCD Screen: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 2.6 mm Phillips screws from the LCD hinges.
      • Tilt the LCD away from the metal frame.
      • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
    2. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use two fingers to pull the ribbon through the hole in the metal frame.
      • Remove the LCD from the metal frame.
    3. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
    4. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
      • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
    5. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to pry the LCD case open.
      • Once the case is open, pull the ribbon through the hole on the back case.
    6. Fujifilm X-M1 LCD Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the LCD from the screen cover.
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
21,532 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 6,596
