Fujifilm X-M1 Back Case Replacement
  1. Fujifilm X-M1 Back Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 Back Case Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 Back Case Replacement, Back Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  3. Fujifilm X-M1 Back Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  4. Fujifilm X-M1 Back Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  5. Fujifilm X-M1 Back Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  6. Fujifilm X-M1 Back Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  7. Fujifilm X-M1 Back Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  8. Fujifilm X-M1 Back Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  9. Fujifilm X-M1 Back Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  10. Fujifilm X-M1 Back Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the frame around the LCD to remove it from the camera.
  11. Fujifilm X-M1 Back Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  12. Fujifilm X-M1 Back Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to unhook the speaker near the left handgrip.
  13. Fujifilm X-M1 Back Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  14. Fujifilm X-M1 Back Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm X-M1 Back Case Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
20 688 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,610
