Fujifilm Instax Mini Eight Camera Shell Replacement
  1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
    • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
  2. Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the tab down in order to unlatch the film compartment cover.
    • Remove the film from the compartment (if any is present)
    • Remove the compartment cover completely.
    • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
  3. Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tools and spudger to safely remove the front shell casing.
  4. Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Instax Mini Eight Camera Shell Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
    • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
    • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
crwdns2935229:013crwdne2935229:0
Boyang Wu
crwdns2935283:010/02/12crwdne2935283:0
1 010 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 4-1, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S4G1
crwdns2935297:026crwdne2935297:0
crwdns2947412:018crwdne2947412:0
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - crwdns2934203:0crwdne2934203:0
but where near the exit? i cannot find it
Emily Birkler -
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - crwdns2934203:0crwdne2934203:0
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 248
crwdns2942667:0crwdne2942667:0 67,442
