Fujifilm Finepix S1000fd Rear Cover Casing Replacement
  1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1000fd Rear Cover Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
Lizzie Eller
crwdns2935283:001/25/17crwdne2935283:0
422 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-7, Banghart Winter 2017 crwdns2935289:0Cal Poly, Team 8-7, Banghart Winter 2017crwdne2935289:0
CPSU-BANGHART-W17S8G7
crwdns2942667:0crwdne2942667:0 746
