Fujifilm FinePix Z1 Lens Barrier Replacement
  1. Fujifilm FinePix Z1 Lens Barrier Replacement, Lens Barrier: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement, Lens Barrier: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When looking at the front of the camera, make sure the front is facing towards you, and then check to see if the lens barrier slides freely without anything coming in its way.
    • Make sure there is no debris trapped between the lens barrier and the camera lens. Examine the edges to see if there is anything that is blocking the movement.
    • Carefully slide the lens barrier back and forth to try to turn the camera back on. To ensure that the camera will turn on, double-check to see that it is properly aligned and on the track
  2. Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the five outer screws ( 4 mm ) which hold the outer casing of the camera together.
    • Use a 1.0 flathead screwdriver and carefully screw the external screws. Make sure to place screws in a secured place.
  3. Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, hold the top and bottom of the casing, and gently pull them apart.
    • Look at the back of the door to make sure the circular spring is still intact. If it is misaligned, carefully move the lens barrier and fix the springs to avoid any of the sticking points.
  4. Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, find a thin flat orange cable. This controls the lens barrier and connects it to the main circuit board in the camera.
    • Carefully check the length of the cable to see that it isn’t frayed or broken. If the cable is broken, further measures will be required.
  5. Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix Z1 Lens Barrier Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the cable is broken, you may have to replace it if it is required.
    • This last step will require you to solder some of the cable connectors. Click here to learn how to complete this step.
Carra
crwdns2935283:001/30/18crwdne2935283:0
533 crwdns2915208:0crwdne2915208:0
Baylor, Team S2-G4, Johnson Spring 2018 crwdns2935289:0Baylor, Team S2-G4, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S2G4
crwdns2942667:0crwdne2942667:0 446
