Fujifilm FinePix XP80 Speaker Replacement
  1. Fujifilm FinePix XP80 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Speaker Replacement, Exterior Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Speaker Replacement, Interior Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Speaker Replacement, Speaker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement, Speaker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the black sticker covering the motherboard.
  16. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a PH000 Phillips bit, remove the four screws shown.
  17. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, carefully remove the lens housing to the left of the motherboard.
  18. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the sticker on the side of the motherboard.
    • Using a PH000 Phillips bit, remove the screw.
  19. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH000 Phillips bit, remove the screw shown.
    • Unclip the three ribbon cables that are still attached to the motherboard.
    • Use the plastic opening tool to gently pry the motherboard loose.
    • Move the motherboard aside slightly to reveal the speaker, which is connected to the motherboard by red and black wires.
  20. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the way, being careful of the speaker wires.
    • Carefully pry the speaker out of its slot in the case.
  21. Fujifilm FinePix XP80 Speaker Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Amanda Lewis
crwdns2935283:009/25/16crwdne2935283:0
317 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 1-3, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S1G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 314
