Fujifilm FinePix XP70 Back Panel Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Fujifilm FinePix XP70 Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Back Panel Replacement, Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement, Button: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the three buttons out.
  6. Fujifilm FinePix XP70 Back Panel Replacement, Front and Back Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the front plate.
  12. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP70 Back Panel Replacement, Back Panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix XP70 Back Panel Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
Olivia A
crwdns2935283:010/24/16crwdne2935283:0
484 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S7-G3, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S7-G3, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S7G3
crwdns2942667:0crwdne2942667:0 51
