The LCD screen on the Fujifilm FinePix T500 is a crucial component that facilitates viewing images, configuring settings, and selecting various modes. This guide is designed to assist you in replacing the LCD screen, allowing you to extend the life of your camera without having to purchase a new one.
Unscrew the six 3.5mm Philips head from the outer casing.
Open the battery compartment and remove the battery.
Carefully pry the front half of the casing away from the camera.
Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
Pry the back half of the casing from the camera.
Lift the LCD screen out of the camera.
Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
