Fujifilm FinePix S8630 Speaker Replacement
  1. Fujifilm FinePix S8630 Speaker Replacement, Battery Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your Philips head screwdriver remove the screws from the metal shield.
    • Remove the metal shield.
  10. Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
    • Identify where the speaker is connected to the motherboard and unsolder both of the connections,
    • Guide for Soldering: How To Solder and Desolder Connections
Colton Lancsarics
crwdns2935283:002/10/16crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 3-2, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S3G2
crwdns2942667:0crwdne2942667:0 434
