Fujifilm FinePix S8630 Button Panel Replacement
  1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
Colton Lancsarics
crwdns2935283:002/10/16crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 3-2, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S3G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 460
