The Selector is an important part of the camera because it controls the LCD screen. To replace it, follow the below steps.
Turn the camera upside down so you can access the battery chamber.
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
With the battery chamber open, remove the old batteries.
Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Carefully pry away the rear housing cover with the plastic opening tool.
Remove the rear housing cover by carefully pulling it away from the camera.
To Replace the Selection button, carefully pull the button until the button has been fully detached.
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
