The rear housing cover protects the back of the camera. If the rear housing cover is cracked or damaged, it should be replaced.
Turn the camera upside down so you can access the battery chamber.
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
With the battery chamber open, remove the old batteries.
Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Carefully pry away the rear housing cover with the plastic opening tool.
Remove the rear housing cover by carefully pulling it away from the camera.
