It happens to best of us. Your device hits the floor and now the case is damaged. Don't panic, because all you need are a screwdriver and a tool to remove the plastic case and you can replace this component very easily.
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Remove all four batteries and set them aside.
Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
Rotate the camera so that the HDMI port is facing up.
Remove the two 5.0 mm JIS #000 screws.
Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
Press the pop-up button highlighted in the picture to release the flash mechanism.
Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
Gently, remove the rear case from the camera and set it aside.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
hey, can you show how to remove the lense from this camera, please!!
hey, can you please show how to remove the lens from this camera. thanks
Thank you for your guide, exactly what i was looking for.
Jordan, web dev at Casinos Hunter Fr
Very interesting and useful guide my friend. Really if you could show us how to remove the lenses on this camera model, it would be just super!
Greetings from Oliver Garcia
Content Master and Graphic Quality Control at CasinoLandia
Great teardown guide — helped me a ton getting into my old FinePix.
It’s funny how taking apart tech and understanding how each piece works reminds me of how we approach odds and betting strategies over at CasinoLogia.
If you’re into systems, logic, and the thrill of solving complex puzzles, you might enjoy what we’re building there.
