In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the LCD screen. This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera. Then, only one ZIF connector stands between you and a new LCD screen.
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Remove all four batteries and set them aside.
Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
Rotate the camera so that the HDMI port is facing up.
Remove the two 5.0 mm JIS #000 screws.
Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
Press the pop-up button highlighted in the picture to release the flash mechanism.
Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
Gently, remove the rear case from the camera and set it aside.
Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
Lift the screen away from the camera and set it aside.
Thank you Stephen for this tutorial. I have two hobbies, photography and video games, especially in games, I am fascinated by music. I know that licensing music for developers is a long process, but thanks to a service like https://www.styngr.com/ music licensing for developers won't be a problem
It's easy to agree that, it's very hard to find a reputable and trustworthy online casino. The only casino I can recommend is GG Bet promokod casino because people trust it. According to statistics https://crongdor.com/ this online casino has the highest RTP.
