Fujifilm FinePix S4200 Viewfinder Replacement
  1. Fujifilm FinePix S4200 Viewfinder  Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
  12. Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
  13. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull off the plastic cover from the view finder.
  14. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm screws surrounding the viewfinder with a Phillips 000 screwdriver.
  15. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orange ribbon is fragile.
    • Using the plastic opening tool, pull down the small black latch to remove the orange ribbon from the mother board.
  16. Fujifilm FinePix S4200 Viewfinder  Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the viewfinder up to remove it from the body of the camera
Melissa Burciaga
crwdns2935283:009/14/15crwdne2935283:0
158 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-4, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 1-4, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S1G4
crwdns2942667:0crwdne2942667:0 1,056
