Following this guide involves the Fujifilm FinePix S1 and is moderately difficult.
Remove the 4 screws surrounding the LCD screen.
Use an opening tool to remove the casing on the hinge of the LCD screen.
Use an opening tool to pry apart the LCD screen casing and remove the casing.
Remove the 2 screws located on the inner corners of the inside of the LCD screen.
Disconnect the blue cable set by carefully prying it off with a spudger.
Use a spudger to lift the LCD screen out of its placement and remove it from the casing.
