Fujifilm FinePix HS30EXR Screen Replacement
  1. Fujifilm FinePix HS30EXR Screen Replacement, Frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  6. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Screen Replacement, Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the ribbon cable is unconnected, pull away the frame to work on.
  11. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the frame component so that the inside is now accessible.
    • With a screwdriver, unscrew all highlighted screws.
  12. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the LCD Screen component so that the bottom half is now accessible.
  13. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD Screen component from its mount.
    • Turn the LCD Screen component so that the right side is now accessible.
  14. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD Screen can now be removed from the LCD Screen Mount.
    • Carefully remove the LCD Screen, as it is attached by another ribbon cable.
  15. Fujifilm FinePix HS30EXR Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the LCD Screen, flip the switch on the ribbon cable's container that is closest to the ribbon cable (highlighted by the red circle).
    • Carefully remove the ribbon cable from its compartment, and remove the LCD Screen.
    • Position your new LCD Screen onto where the old one was removed from, and reattach the ribbon cable (ensure that the switch is now clamped down; a light tug should not dislodge the ribbon cable).
crwdns2935229:05crwdne2935229:0
Andrew Scouten
crwdns2935283:010/22/18crwdne2935283:0
886 crwdns2915208:0crwdne2915208:0
Baylor, Team S1-G2, Williams Fall 2018 crwdns2935289:0Baylor, Team S1-G2, Williams Fall 2018crwdne2935289:0
BU-WILLIAMS-F18S1G2
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
Bernard MRT - crwdns2934203:0crwdne2934203:0
Thanks I have fixed the screen on my camera now it works perfect
Colin Head - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,054
