The sensor of the camera detects and conveys information used to make an image. If the sensor is damaged, the camera can not take a picture properly. If your pictures are coming out dark or faded, etc., you may need to replace the sensor. Follow the steps in this guide to safely replace the sensor.
The camera will be completely open in this replacement. Make you carefully look at the pictures to see which parts you are working with, so you are not removing the wrong thing.
Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
Use a plastic pick to separate each side of the camera case apart.
Remove the ribbon cable from the side of logic board.
Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
Remove the three screws holding the sensor.
Remove the sensor ribbon cable from the logic board.
