crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Fujifilm Cameracrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Fujifilm Camera Teardown, Fujifilm Camera Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, Fujifilm Camera Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, Fujifilm Camera Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • tools needed
    • Phillips 00 screwdriver
    • "Y" screwdriver
    • tweezers
    • small needle nose pliers
    • small plastic pry tool
    • plastic spudger
    • the iFixit Pro Tech tool kit contains all necessary tools for this job
  2. Fujifilm Camera Teardown, open it up: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the 2 Phillips 00 screws from the bottom
    • remove the 1 Phillips 00 screws from the side
    • remove the 2 "Y" screws from the other side
  3. Fujifilm Camera Teardown, remove back: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • use your plastic pry tool to remove the back of the camera
    • make sure the battery door is open as it will hold the back in place
    • remove back carefully camera has a ribbon cable running to the digitizer screen
    • disconnect digitizer cable
  4. Fujifilm Camera Teardown, remove view finder: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, remove view finder: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, remove view finder: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • you should have already disconnected the copper ribbon cable and the molex connector with the pink and white wires.
    • wiggle the view finder gently until it comes lose
  5. Fujifilm Camera Teardown, remove battery compartment: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • there is a small white ribbon cable attached to the battery compartment and the cameras logic board verify that it's disconnected
    • there is a molex connector with a black wire and a red wire coming from the battery compartment going to the cameras logic board. disconnect this wire from the logic board.
    • using your plastic pry tool carefully free battery compartment from the camera housing
  6. Fujifilm Camera Teardown, LCD removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, LCD removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, LCD removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the 2 Phillips screws securing the LCD one is in the upper left corner and the other is on the lower right corner
    • gently lift the top of the LCD panel towards you
    • use caution not to damage the copper ribbon cable behind the display
    • use a plastic pry tool to release the latch that secure the cable to the logic board
    • gently pull the ribbon cable from the logic board
  7. Fujifilm Camera Teardown, Removal of logic board 1: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, Removal of logic board 1: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujifilm Camera Teardown, Removal of logic board 1: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • STILL WORKING ON THIS GUIDE PLEASE CHECK BACK
Timothy Fogg
crwdns2935283:012/08/14crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,404
