This replacement guide will show you how to access the battery terminal leads on a Fujifilm FinePix S5100 camera. It is recommended to use a magnetic pad to place the screws on in conjunction with the magnetic tools mentioned above. This is to prevent or minimize the chances of losing or misplacing a screw. Be mindful of this with regards to safe handling of the electrical components. This guide is fairly simple and does not require a large amount of time.
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Open the battery door by pushing down and in the direction of the arrow on the door.
Remove four AA batteries from the camera.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
Remove two 0.9mm Phillips #000 screws from the right side of the camera.
Remove one 0.6mm Phillips #000 screw from the left side of the camera.
Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
Carefully pull the back cover and separate it from the rest of the camera body.
Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
Remove the single 1.3mm Phillips #000 screw.
Carefully remove the battery compartment from the rest of the camera.
Remove two 0.6mm Phillips #000 screws from the metal battery terminal lead.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, remove the two back panel pieces from the battery terminal leads found inside of the battery compartment door.
Using the a pair of tweezers, remove one (+)positive and one (-)negative battery terminal leads from the battery compartment.
hello, could you help me with the repair of the power button of a camera fuji finepix HS 20 EXR since the problem lies in the fact that after pressing the trigger and taking a photo, the camera turns off.
