FujiFilm FinePix S5100 Battery Door Replacement
  1. FujiFilm FinePix S5100 Battery Door Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Battery Door Replacement, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
  6. FujiFilm FinePix S5100 Battery Door Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 1.3mm Phillips #000 screw.
    • Carefully remove the battery compartment from the rest of the camera.
  7. FujiFilm FinePix S5100 Battery Door Replacement, Battery Door: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix S5100 Battery Door Replacement, Battery Door: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully pull the 4.4mm rod out of the battery compartment.
    • Once the rod is out, the door can easily be removed.
Christopher Coviello
crwdns2935283:009/14/19crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G1, Salas Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G1, Salas Fall 2019crwdne2935289:0
ERAU-SALAS-F19S6G1
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 1,678
