The LCD is one of the most critical parts on the camera. This guide will show you how to remove the back panel of the camera in order to replace a faulty LCD screen.
Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
Use a plastic opening tool to separate the back panel from the camera on the left side.
Use a plastic opening tool to separate the back panel from the camera on the bottom.
Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
Use a plastic opening tool to separate the LCD screen from the camera.
Flip up the black tab holding the LCD ribbon wire in place and remove wire.
