FujiFilm FinePix A340 Flash Unit Replacement
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push both blue switches away from the holding device to detach the LCD ribbon.
    • Be careful when removing the ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black sticky tape from the circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing the assembly as to not break any solder leads or damage the lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard by pulling it straight away from the assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FujiFilm FinePix A340 Flash Unit Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the flash unit at its three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
    • Learn more about electronics soldering here.
Cody
crwdns2935283:004/18/10crwdne2935283:0
47 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-11, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 7-11, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S7G11
crwdns2942667:0crwdne2942667:0 4,029
