Begin by unscrewing the four 10.72 mm corner screws using the Hex 2.0 screwdriver.
Using the Hex 1.5 screwdriver, remove the remaining six 5.79 mm screws on the front of the speaker.
Pull the front part of shell away from the back part of shell.
Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
Pull on the speaker covers to remove them.
Rotate the speaker 180 degrees and then remove the four 5.57 mm screws on the side speaker that has the power/bluetooth buttons.
Pull apart the side speaker and its casing away from the body of the Fugoo.
After pulling apart the side speaker and its casing, you will see both the power and Bluetooth buttons on the underside of the circuit board.
Desolder the power button and replace it on the motherboard.
Where can I buy the screwdrivers to remove the 4-5.57mm screws?
Where can you find/source replacement power switches?
