crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
crwdns2959928:0crwdne2959928:0 ↓This guide will walk you through how you remove the front panel assembly which contains the screen along with the front glass and capacitive buttons.
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Remove the button cover by lifting the cover away from the tablet.
Using the Torx screwdriver, remove the 4mm screws.
With the Torx screwdriver, remove the two 5mm screws.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
