Frigidaire FFPE45B2QM Broken Hinge Replacement
  1. Frigidaire FFPE45B2QM Broken Hinge Replacement, Broken Hinge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Broken Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Broken Hinge Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire FFPE45B2QM Broken Hinge Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
Peterluchini
crwdns2935283:011/05/15crwdne2935283:0
568 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-2, Bhusal Fall 2015crwdne2935289:0
UMASSD-BHUSAL-F15S1G2
That might work on the TOP hinge, but on the bottom hinge the refrigerator would have to be tilted or laid on its side. Also, you could have used a hex socket of the appropriate size instead of the “JIS #1 screw driver“ to remove the bolts.
My refrigerator is a Whirlpool that uses top hinge bolts that require an allen wrench. The bottom is another can of worms, especially with the auto-close.
The previous Whirlpool model had a bottom hinge with a plastic / nylon piece to make it close. When it broke, I made an aluminum piece that kept the door closed.
doctordon - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 672
