Frigidaire CFEF3012PWC Heat Switch Repair
  1. Frigidaire CFEF3012PWC Heat Switch Repair, Heat Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To be safe, disconnect the power at the breaker. This avoids electrical injury when working with the oven.
  2. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the oven from the receptacle to be safe.
    • Move it to an open area so there is enough space to work with.
  3. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the panel from the back. You may have a top or bottom cover, depending on your model.
    • The screwdriver used should be a square head.
    • If the screws are tight, use pliers to remove them.
  4. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the multimeter to ohms. Otherwise, you may generate a short circuit if you do not have the correct setting.
  5. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You must disconnect the wires to prevent electrical issues from occurring.
    • Remember where the original wires were placed. It's good to take a photo before doing so.
  6. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Look at the switch for the terminals. This differs depending if you have a standard surface element or a dual ring element(dual burner). But, it will be labeled.
    • In this case, the L1 to H1 and L2 to H2 terminals will be checked. (L=line, H=heat). Black goes on L and Red goes on H. The position may differ depending on your switch. Read the label on your switch.
    • Once you've figured that out, make sure to turn your heat dial to HI
  7. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the switch for the L1 to H1 terminals
  8. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the switch for the L2 to H2 terminals.
  9. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If it does not read from 0 to 1, you must replace the switch because there is no continuity.
  10. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have a dual ring element then you can check the connectivity between the pairings for it. In this case, it is not present in either side of the back.
    • You may have other power models, but the process remains the same. If there is no connectivity, it has to be replaced.
  11. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the switch has been confirmed to be faulty, Pull the heat dial out and remove the screws.
  12. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the heat dial is removed, you can easily remove the switch and then connect the new switch to the dial.
    • Connect the wires in the same position you had seen with the old switch.
  13. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the remaining components
Saad
crwdns2935283:009/10/23crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
York University, Team 2-22, O'Regan Fall 2023 crwdns2935289:0York University, Team 2-22, O'Regan Fall 2023crwdne2935289:0
YORK-O'REGAN-F23S2G22
crwdns2942667:0crwdne2942667:0 169
