Frigidaire CFEF3012PWC Heat Switch Repair
  1. Frigidaire CFEF3012PWC Heat Switch Repair, Heat Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To be safe, disconnect the power at the breaker. This avoids electrical injury when working with the oven.
  2. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the oven from the receptacle to be safe.
    • Move it to an open area so there is enough space to work with.
  3. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the back panel of the stove. Depending on your model, the cover may be located on the top or bottom.
    • Use a square head screwdriver.
    • If the screws are tight, use pliers to remove them.
  4. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the multimeter to ohms. Otherwise, you may generate a short circuit if you do not have the correct setting.
  5. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You must disconnect the wires to prevent electrical issues from occurring.
    • Remember where the original wires were placed. It's good to take a photo before doing so.
  6. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the terminals on the switch. These can look different depending on whether your burner is a standard or a dual burner. Each terminal should be labeled.
    • In this case, the L1 to H1 and L2 to H2 terminals will be checked. (L=line, H=heat). Black goes on L and Red goes on H. The position may differ depending on your switch. Read the label on your switch.
    • After finding the terminals, turn the heat dial to “HI”.
  7. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the switch for the L1 to H1 terminals
  8. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the switch for the L2 to H2 terminals.
  9. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the multimeter does not read between 0 and 1, the switch has no durability and must be replaced.
  10. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have a dual burner, test both sets of terminals for durability.
    • You may have other power models, but the process remains the same. If there is no connectivity, it has to be replaced.
  11. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the switch is confirmed to be faulty, pull the heat dial out and remove the screws that are holding the switch in place.
  12. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the heat dial is removed, remove the old switch and replace with the new switch.
    • After the switch, connect the new switch to the heat dial.
  13. Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Frigidaire CFEF3012PWC Heat Switch Repair: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect any remaining parts that were removed earlier.
Saad
crwdns2935283:009/10/23crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
York University, Team 2-22, O'Regan Fall 2023 crwdns2935289:0York University, Team 2-22, O'Regan Fall 2023crwdne2935289:0
YORK-O'REGAN-F23S2G22
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 363
