Use this guide to replace one or both touchpad spacers in your Framework 16" laptop.
Note: the laptop used in this guide is a generic setup of one US keyboard, one numpad module, and two touchpad spacers. Your setup might vary, but the procedure should remain the same.
Unplug all cables and fully shut down your laptop.
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
Lift the touchpad spacer off the laptop and remove it.
Repeat the same procedure for the other touchpad spacer.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
