Framework Laptop 12 Power Button Board Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Framework Laptop 12 Power Button Board Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Power Button Board Removal, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Power Button Board Removal, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Framework Laptop 12 Power Button Board Removal, Flip your laptop over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Power Button Board Removal, Open your laptop: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Open your laptop: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Power Button Board Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Power Button Board Removal, Loosen the Power Button Board screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
  8. Framework Laptop 12 Power Button Board Removal, Remove the Power Button Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Power Button Board Removal, Remove the Power Button Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and remove the Power Button Board.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,992 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
crwdns2942667:0crwdne2942667:0 23
