A set of installation steps that go after the hinge guides, but before the bottom cover disconnect prereq
This is the installation version of the Pre-hinge Removal Steps
Carefully swing the display onto the Top Cover such that the top edge of the display sits slightly below the top edge of the Top Cover.
Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
Use your Framework Screwdriver to install the four 3.2 mm‑long T5 Torx screws to secure the display to the Top Cover.
Lay the Display Cover in place below the display.
Use your finger to press along the length of the Display Cover to snap it onto the laptop.
