Memory module/RAM removal prereq guide
Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
Set your Framework Laptop face-down on a clean work surface.
Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
Flip your laptop over so it's face-up on your work surface.
Open the laptop lid so that both the screen and the base lie flat on your work surface.
Use your fingers to grip the Input Cover in the hinge cutouts.
Lift upwards to swing the Input Cover up from the base of the laptop.
Remove the Input Cover.
Use your fingers to flip open the memory flap.
Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
Use your fingers to grab the memory module by its edges.
Slide the memory module out of its socket and remove it.
