Framework Laptop 12 Mainboard Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Framework Laptop 12 Mainboard Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Mainboard Removal, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Mainboard Removal, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  4. Framework Laptop 12 Mainboard Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the lip of an Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
    • Repeat this procedure to remove all remaining Expansion Cards.
  5. Framework Laptop 12 Mainboard Removal, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  6. Framework Laptop 12 Mainboard Removal, Flip your laptop over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop face-up on your work surface.
  7. Framework Laptop 12 Mainboard Removal, Open your laptop: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Open your laptop: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  8. Framework Laptop 12 Mainboard Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
    • Remove the Input Cover.
  9. Framework Laptop 12 Mainboard Removal, Loosen the battery screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  10. Framework Laptop 12 Mainboard Removal, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  11. Framework Laptop 12 Mainboard Removal, Remove the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  12. Framework Laptop 12 Mainboard Removal, Open the memory flap: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Open the memory flap: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to flip open the memory flap.
  13. Framework Laptop 12 Mainboard Removal, Remove the memory module: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the memory module: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
    • The memory module will pop up to an angle when it's unclipped.
  14. Framework Laptop 12 Mainboard Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the memory module by its edges.
    • Slide the memory module out of its socket and remove it.
  15. Framework Laptop 12 Mainboard Removal, Unlatch the SSD: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Unlatch the SSD: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to press down on the black SSD latch to unlatch the SSD.
    • The SSD will pop up to an angle when it's unlatched.
  16. Framework Laptop 12 Mainboard Removal, Remove the SSD: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the SSD: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the SSD: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  17. Framework Laptop 12 Mainboard Removal, Loosen the Audio Board screw: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
  18. Framework Laptop 12 Mainboard Removal, Remove the Audio Board: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Audio Board: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Audio Board: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
    • Remove the Audio Board.
  19. Framework Laptop 12 Mainboard Removal, Loosen the Power Button Board screw: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
  20. Framework Laptop 12 Mainboard Removal, Remove the Power Button Board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Power Button Board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and remove the Power Button Board.
  21. Framework Laptop 12 Mainboard Removal, Loosen the Wi-Fi card screw: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
    • The Wi-Fi card will pop up slightly when you unfasten the bracket.
  22. Framework Laptop 12 Mainboard Removal, Remove the Wi-Fi card bracket: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Wi-Fi card bracket: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card bracket with your fingers and slide it off the top of the Wi-Fi card.
    • Remove the bracket and store it in a safe location for reassembly.
  23. Framework Laptop 12 Mainboard Removal, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the antenna cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Wi-Fi card has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi card down with your finger.
    • Slide the flat edge of your Framework Screwdriver under the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  24. Framework Laptop 12 Mainboard Removal, Remove the Wi-Fi card: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Wi-Fi card: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card by the edges and pull it out of its socket.
    • Remove the Wi-Fi card.
  25. Framework Laptop 12 Mainboard Removal, Disconnect the fan connector: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the fan connector: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the fan connector: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
  26. Framework Laptop 12 Mainboard Removal: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
  27. Framework Laptop 12 Mainboard Removal, Loosen the fan screws: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
  28. Framework Laptop 12 Mainboard Removal, Remove the fan: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the fan: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the fan.
  29. Framework Laptop 12 Mainboard Removal, Loosen the heatsink screws: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the heatsink.
  30. Framework Laptop 12 Mainboard Removal, Loosen the heatsink: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Loosen the heatsink: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Loosen the heatsink: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the flat end of your Framework Screwdriver under the heatsink arm labeled "2".
    • Gently twist the Framework Screwdriver to lift the heatsink arm and loosen the heatsink.
    • You'll feel some resistance from the thermal compound holding the heatsink in place. Stop if the heatsink arm begins to bend.
    • If the heatsink won't budge, make sure you've fully loosened the four screws securing the heatsink.
    • Repeat the procedure with the heatsink arm labeled "3".
  31. Framework Laptop 12 Mainboard Removal, Remove the heatsink: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the heatsink: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the heatsink.
  32. Framework Laptop 12 Mainboard Removal, Loosen the Wi-Fi card screw: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  33. Framework Laptop 12 Mainboard Removal, Reposition the Wi-Fi card: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Reposition the Wi-Fi card: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to strain the two delicate antenna cables attached to the Wi-Fi card.
    • Grab the Wi-Fi card by its edges and slide it out of its socket.
  34. Framework Laptop 12 Mainboard Removal: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully reposition the Wi-Fi card away from the Mainboard.
    • If the clear bracket or an antenna cable detaches from the Wi-Fi card, don't worry! You can reattach it during reassembly.
  35. Framework Laptop 12 Mainboard Removal, Disconnect the webcam cable: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the webcam cable: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Lift straight up to disconnect the cable.
  36. Framework Laptop 12 Mainboard Removal, Disconnect the display cable: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Disconnect the display cable: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
  37. Framework Laptop 12 Mainboard Removal, Loosen the Mainboard screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
    • These screws are also physically marked with an orange ring on the Mainboard.
  38. Framework Laptop 12 Mainboard Removal, Remove the Mainboard: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Mainboard Removal, Remove the Mainboard: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
    • Use your fingers to grab the Mainboard by its edges.
    • Lift and remove the Mainboard.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,095 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
crwdns2942667:0crwdne2942667:0 39
