A set of removal steps that install the display while the entire top cover's disconnected.
The installation version of Loosen the Display (separated).
Lay the display in place in the Top Cover, such that the top edge of the display is slightly below the top edge of the Top Cover.
Use your fingers to slide the display upwards to latch the tabs on the top edge of the display.
Use your Framework Screwdriver to install the four 3.3 mm‑long T5 Torx screws to secure the display to the Top Cover.
Use your fingers to twist both hinge plates so they're flipped over the display.
Place the cable clip around the right hinge cables, where they were bent from being inserted into the hinge.
Use your fingers to press the clip into the hinge to secure the cables.
Repeat the procedure on the left hinge to secure the left cables.
Make sure both cable clips are fully inserted into the hinges, so that they won't be snagged when the hinges pivot.
Use your fingers to twist both hinge plates so that they lay flat on your work surface.
Lay the Display Cover in place below the display.
Use your finger to press along the length of the Display Cover to snap it onto the laptop.
