crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
Set your Framework Laptop face-down on a clean work surface.
Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
Grip the lip of an Expansion Card with your fingers.
Pull the Expansion Card out of its slot and remove it.
Repeat this procedure to remove all remaining Expansion Cards.
Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
Flip your laptop face-up on your work surface.
Open the laptop lid so that both the screen and the base lie flat on your work surface.
Use your fingers to grip the Input Cover in the hinge cutouts.
Lift upwards to swing the Input Cover up from the base of the laptop.
Remove the Input Cover.
