Framework Laptop 12 Hinge (Right) Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Framework Laptop 12 Hinge (Right) Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Hinge (Right) Removal, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Hinge (Right) Removal, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Expansion Cards: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
    • The latches display a red bar when they're unlocked.
  4. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the lip of an Expansion Card with your fingers.
    • Pull the Expansion Card out of its slot and remove it.
    • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
    • Repeat this procedure to remove all remaining Expansion Cards.
  5. Framework Laptop 12 Hinge (Right) Removal, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Loosen the bottom screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  6. Framework Laptop 12 Hinge (Right) Removal, Flip your laptop over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop face-up on your work surface.
  7. Framework Laptop 12 Hinge (Right) Removal, Open your laptop: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Open your laptop: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  8. Framework Laptop 12 Hinge (Right) Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Input Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
    • Remove the Input Cover.
  9. Framework Laptop 12 Hinge (Right) Removal, Loosen the battery screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  10. Framework Laptop 12 Hinge (Right) Removal, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  11. Framework Laptop 12 Hinge (Right) Removal, Remove the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  12. Framework Laptop 12 Hinge (Right) Removal, Loosen the Audio Board screw: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
  13. Framework Laptop 12 Hinge (Right) Removal, Remove the Audio Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Audio Board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Audio Board: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
    • Remove the Audio Board.
  14. Framework Laptop 12 Hinge (Right) Removal, Loosen the Power Button Board screw: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
  15. Framework Laptop 12 Hinge (Right) Removal, Remove the Power Button Board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Power Button Board: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and remove the Power Button Board.
  16. Framework Laptop 12 Hinge (Right) Removal, Loosen the Wi-Fi card screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
    • The Wi-Fi card will pop up slightly when you unfasten the bracket.
  17. Framework Laptop 12 Hinge (Right) Removal, Remove the Wi-Fi card bracket: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Wi-Fi card bracket: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card bracket with your fingers and slide it off the top of the Wi-Fi card.
    • Remove the bracket and store it in a safe location for reassembly.
  18. Framework Laptop 12 Hinge (Right) Removal, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the antenna cables: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Wi-Fi card has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi card down with your finger.
    • Slide the flat edge of your Framework Screwdriver under the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  19. Framework Laptop 12 Hinge (Right) Removal, Remove the Wi-Fi card: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Wi-Fi card: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Wi-Fi card by the edges and pull it out of its socket.
    • Remove the Wi-Fi card.
  20. Framework Laptop 12 Hinge (Right) Removal, Disconnect the fan connector: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the fan connector: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the fan connector: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
  21. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
  22. Framework Laptop 12 Hinge (Right) Removal, Loosen the fan screws: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
  23. Framework Laptop 12 Hinge (Right) Removal, Remove the fan: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the fan: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the fan.
  24. Framework Laptop 12 Hinge (Right) Removal, Disconnect the webcam cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the webcam cable: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Lift straight up to disconnect the cable.
  25. Framework Laptop 12 Hinge (Right) Removal, Disconnect the display cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the display cable: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
  26. Framework Laptop 12 Hinge (Right) Removal, Loosen the Mainboard screws: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
    • These screws are also physically marked with an orange ring on the Mainboard.
  27. Framework Laptop 12 Hinge (Right) Removal, Remove the Mainboard: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Mainboard: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
    • Use your fingers to grab the Mainboard by its edges.
    • Lift and remove the Mainboard.
  28. Framework Laptop 12 Hinge (Right) Removal, Unthread the antenna cable: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Unthread the antenna cable: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the black plastic loop securing the antenna cable, near the heat vents by the left hinge.
  29. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift and guide the antenna cable out of the frame channel.
  30. Framework Laptop 12 Hinge (Right) Removal, Unthread the webcam cable: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Unthread the webcam cable: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently lift the webcam cable out of its plastic channel.
  31. Framework Laptop 12 Hinge (Right) Removal, Disconnect the Top Cover: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Disconnect the Top Cover: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to remove the six (three per hinge) 4.5 mm‑long T5 Torx screws securing the two hinges.
    • These screws are not captive. Store them in a safe location for reassembly.
  32. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the hinges over the Bottom Cover lip.
    • Separate the Top Cover from the Bottom Cover.
  33. Framework Laptop 12 Hinge (Right) Removal, Remove the Display Cover: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the Display Cover: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Display Cover is held in place with magnets along its top edge and clips along its remaining edges.
    • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
  34. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
  35. Framework Laptop 12 Hinge (Right) Removal: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Display Cover
  36. Framework Laptop 12 Hinge (Right) Removal, Remove the display screws: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to remove the four 3.2 mm‑long T5 Torx screws securing the display to the Top Cover.
  37. Framework Laptop 12 Hinge (Right) Removal, Slide the display down: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Slide the display down: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to hold the bottom edge of the Top Cover in place.
    • Insert the bit end of your Framework Screwdriver into the small hole on the display, below the Framework logo.
    • Slide the display down towards the hinge edge to release the tabs holding the top edge of the display in place.
  38. Framework Laptop 12 Hinge (Right) Removal, Lift the display: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Lift the display: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the top edge of the display from the Top Cover.
  39. Framework Laptop 12 Hinge (Right) Removal, Swing the display out: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Swing the display out: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the top edge of the display.
    • Carefully swing the display over so it lies face-down on your work surface.
    • Be careful not to strain the cables that are still attached to the display.
  40. Framework Laptop 12 Hinge (Right) Removal, Remove the right hinge screws: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to remove the two 2.4 mm‑long T5 Torx screws securing the right hinge to the Top Cover.
  41. Framework Laptop 12 Hinge (Right) Removal, Swing the display back: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Swing the display back: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully swing the display back onto the Top Cover.
  42. Framework Laptop 12 Hinge (Right) Removal, Angle the hinge out: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Angle the hinge out: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the hinge over the Top Cover lip and angle it out of the Top Cover.
  43. Framework Laptop 12 Hinge (Right) Removal, Pry out the cable clip: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Pry out the cable clip: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the T5 Torx bit on your Framework Screwdriver or a spudger to pry out the black cable clip from within the right hinge.
    • Store the clip in a safe place for reassembly.
  44. Framework Laptop 12 Hinge (Right) Removal, Remove the hinge: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the hinge: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Hinge (Right) Removal, Remove the hinge: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the cables out of the hinge.
    • Remove the right hinge.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298.001 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
crwdns2942667:0crwdne2942667:0 28
