Right hinge installation prereq guide
Place the cable clip around the cables, where they were bent from being inserted into the hinge.
Use your fingers to press the clip into the hinge to secure the cables.
Make sure the cables are properly routed in the Top Cover.
Use your fingers to place the right hinge back in place in the Top Cover.
Use your fingers to carefully swing the display over so it lies face-down on your work surface.
Use your Framework Screwdriver to install the two 2.4 mm‑long T5 Torx screws to secure the right hinge to the Top Cover.
crwdns2935219:0crwdne2935219:0
