Framework Laptop 12 Heatsink Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Framework Laptop 12 Heatsink Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Heatsink Removal, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Heatsink Removal, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. Framework Laptop 12 Heatsink Removal, Flip your laptop over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Heatsink Removal, Open your laptop: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Open your laptop: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Heatsink Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Remove the Input Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Heatsink Removal, Loosen the battery screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  8. Framework Laptop 12 Heatsink Removal, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  9. Framework Laptop 12 Heatsink Removal, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  10. Framework Laptop 12 Heatsink Removal, Loosen the heatsink screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the four captive Torx T5 screws securing the heatsink.
  11. Framework Laptop 12 Heatsink Removal, Loosen the heatsink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Loosen the heatsink: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Loosen the heatsink: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the flat end of your Framework Screwdriver under the heatsink arm labeled "2".
    • Twist the Framework Screwdriver to lift the heatsink arm and loosen the heatsink.
    • You'll feel some resistance from the thermal compound holding the heatsink in place.
    • If the heatsink won't budge, make sure you've fully loosened the four screws securing the heatsink.
    • Repeat the procedure with the heatsink arm labeled "3".
  12. Framework Laptop 12 Heatsink Removal, Remove the heatsink: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Heatsink Removal, Remove the heatsink: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the heatsink.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298.104 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
crwdns2942667:0crwdne2942667:0 26
