Framework Laptop 12 Bottom Cover Reconnect
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect, Reconnect the Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the Top Cover hinges over the Bottom Cover lip.
    • Lay the hinges in place in the Bottom Cover.
    • Use the plastic alignment pins to align each hinge in place.
  2. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to install the six 4.5 mm‑long T5 Torx screws securing the two hinges.
  3. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently press the webcam cable into its plastic channel.
  4. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers and your Framework Screwdriver to carefully press and guide the black antenna cable back into its channel.
    • Zoom in on the second image to see how the antenna cable sits in its channel.
  5. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the black loop over the antenna cable and onto the Bottom Cover. If it doesn't stick, use a bit of thin double-sided tape to hold it down.
  6. Framework Laptop 12 Bottom Cover Reconnect, Install the Mainboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect, Install the Mainboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lay the Mainboard in the laptop.
    • Use the two alignment pins to help align the Mainboard to the laptop.
    • Be careful not to trap the webcam, display, and antenna cables under the Mainboard as you set it in place.
  7. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
  8. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
    • Align and press the display cable straight down onto its connector.
  9. Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Framework Laptop 12 Bottom Cover Reconnect: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
    • Align and press the webcam cable straight down onto its connector.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,992 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
crwdns2942667:0crwdne2942667:0 24
