Orient the Top Panel so its arrow is pointing towards the rear of the computer.
While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
Lay the Top Panel flat on the chassis to align the remaining clips.
While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
Insert the top panel screw into its hole and twist clockwise until it feels snug.
Repeat the same procedure for the other top panel screw.
Use your finger to close the two D-rings on the top panel screws.
