Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
Lay the fan duct on top of the fan with the lip facing upward.
Align the screw holes on the fan duct with the ones on the fan.
Remove the fan screws from their packaging and make sure there are four screws total.
Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
Orient the main fan cable so its two vertical lines are facing you.
Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
Orient the RGB cable so the arrow is facing you.
Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
